carb set up / 25mm phbl
Post  littlemoon on Tue Dec 27, 2016 9:29 am
need some base line/ ball park jetting info please.
just fitted new dellorto 25mm phbl carb to my vega. its now reed valved using an lth reedvalve also cc is up to about 90cc and a proper expansion pipe is fitted.
i fitted the carb as it came , brand new. it starts and runs ok just dosent rev out clean . will strip carb and have a look to see what jets and slide and float valve etc are in there. is anyone else using one of these carbs ?? . cheers simon
carb has 102 main
70 idle
60 choke.
40 slide
d22 needle
aq 266 atomiser
if this helps, cheers simon
