My Lui 125 conversion
Page 5 of 11 Previous  1, 2, 3, 4, 5, 6 ... 9, 10, 11  Next
Re: My Lui 125 conversion
Post  NIGE on Mon Jul 29, 2013 7:32 am
that should look cool snails.cant beat a bright vega and cut down handle bars are the bees knees
Post  Snails on Wed Sep 04, 2013 1:19 pm
I've been making slow but steady progress - I had a bit of an issue with the front wheel being wonky (caused by some damage i'd inflicted to the bracket holding one of the lower fork rubber buffers) but hopefully that's fixed now.
Should have it on two wheels in the near future with any luck
Post  daz.h on Wed Sep 04, 2013 3:15 pm
tut tut, legsheilds before forks Wink
Post  Snails on Wed Sep 04, 2013 11:58 pm
No?
Really?
Post  Snails on Thu Sep 05, 2013 12:44 am
Doh!
I was just testing to make sure they fit ok
Wink
Post  Snails on Mon Sep 09, 2013 6:09 am
As i was saying (cough cough) I should have it on two wheels in the near future with any luck Wink
Post  Snails on Wed Sep 11, 2013 2:43 pm
Back on its wheels at last
Now the last really tricky bit - getting the wiring loom sorted
I'm a bit worried about how wasting paint is to chip , it seems much easier than the last one I got
Post  daz.h on Thu Sep 12, 2013 2:51 am
you must like a challenge snails, the loom will be a pain to put in with the engine in place
Post  Snails on Thu Sep 12, 2013 3:24 am
Lol I guess it will although I need to get one custom made so I need the engine in to work out dimensions I think
Post  daz.h on Thu Sep 12, 2013 5:34 am
custom made loom? why ?
Post  Snails on Thu Sep 12, 2013 8:12 am
Well because of the fact that my old loom is a Lui one and intend to fit a rear brake light activated by front and rear brakes, a vega light housing so I can have full and dipped beam and lastly because of the electronic conversion and that I have changed the position of the junction box - see my post on LCGB forum - but thinking about it on the way home from work I'm wondering if I can get away with a Vega one.
To answer this question I could really do with seeing where the loom goes to fit the junction box on a Vega. Any pics by anyone would be appreciated
I intend to fit a LED brake light to a lui light unit so the loom may need some modification at the back light too I guess as a Vega had a single duel filament bulb.
Post  Snails on Thu Sep 12, 2013 1:45 pm
Talking of which am I right in thinking that the loom on a Vega comes out from under the rear mudguard and then to the junction box? If I used a Vega loom and routing I think these would too short.
Also is the loom not crushed by the mudguard? Or is there a hole in the frame or mudguard for the loom to pass through?
Post  daz.h on Thu Sep 12, 2013 3:17 pm
the loom does come out from under the rear mudguard to the junction box.
be aware mate that the loom also come out of a hole where the engine mount spindle is, I had an early lui frame many years ago, and that hole was not present Exclamation
Post  Snails on Fri Sep 13, 2013 12:44 am
Why does that not surprise me.
Why why why did thry bother
Mine has the hole you mention it also used to have some wires that passed under a frame strutt now that I think about it. That connected to the flywheel cover. I hope that this is not normal on the vega or I could be lifting my leggies!
Any chance you could measure the length of the cables from rear mudguard to, is it the coil? Or a junction box?
Post  daz.h on Fri Sep 13, 2013 11:34 am
Crying or Very sad hate to be bearer of bad news snails, but the loom does run under the legsheilds and on top of the rear left strut and then front left then goes up to the fork stem from inside of the legsheilds.
Post  daz.h on Fri Sep 13, 2013 11:41 am
http://lunaownersclub.lifediscussion.net/t34p75-latest-project
look at pics on page 6 and 7, they might help matey.
Post  Snails on Fri Sep 13, 2013 12:27 pm
Thanks Daz, that's alright regarding the bad news, once you have put it together and then taken it apart again a few times you get really quick at it Smile
Do you think you could measure me the loom length from mudguard to junction box/coil? No huge rush as I have other thing to sort that will keep me occupied. Rolling Eyes Very Happy
loom
Post  wack 63 on Fri Sep 13, 2013 5:19 pm
It's far easier to make a loom and use the thinwall cable,you only need 4 wires ,ignition,main feed to lights ,horn and brake switches ( T - offs) another for rear light feed and one more from brake switch to rear light. Then you only have the one wire coming from the regulator.
Post  Snails on Mon Sep 16, 2013 9:16 am
You I think you are probably right Wack
I have drafted up this as a wiring diagram. Any thoughts positive or negative welcome.
I've based most of this on my old wiring from the Lui which worked as far as getting the engine running, the parts I have and what Wack and Daz have given me as information. I've tried looking at a Vega wiring diagram but that justt servers to confuse me even more!
The bit i'm least sure about is the blue from the regulator connecting up with the brown from the horn but that's what I did with the Lui as it only had three wires from the headlight - brown, black (to rear light) and green (to coil obviously)
Post  Snails on Wed Sep 18, 2013 1:19 pm
Oh and thinking about my diagram I've realised that I need some way of powering the rear light and brake light separately as I will not be using a duel filament bulb like in a Vega but a Lui rear light with the addition of a LED for the brake light. I've no real idea of how to do that either.
Post  daz.h on Wed Sep 18, 2013 3:45 pm
scratch you don't do things the easy way snails do you. Very Happy
Post  Snails on Thu Sep 19, 2013 6:04 am
Lol no. I just wish I'd bought a Vega!
What do you think? Looks good? Or don't know? I might throw the question up on the LCGB forum. There's some pretty clued up electrical bods on there.
Post  daz.h on Thu Sep 19, 2013 1:50 pm
throw it over to the otherside snails, the led's generally work better with dc current, I dare say someone will be able to draw up a loom for you to follow.
Post  Snails on Thu Sep 19, 2013 2:48 pm
My LCGB forum post for anyone interested
http://www.forums.ilambretta.com/viewtopic.php?f=2&t=43334
