Kickstart Shaft fitting
Post  storkfoot on Tue Nov 07, 2017 3:18 pm
I could probably do with putting up a picture, but let me try and explain first.
I am used to Series 3s and the way the kickstart shaft fits into the sidecasing. I can see my Vega is different!
I have changed the O ring on the shaft that fits in to the casing. As there is no oil seal, am I correct in assuming that this O ring is all there is to keep it oil tight?
Secondly, am I correct in saying that there is no circlip holding a shim in on the outside, ie in between the shim and the kickstart kever?
storkfoot
Re: Kickstart Shaft fitting
Post  Snails on Wed Nov 08, 2017 6:12 am
No circlip on mine
The whole of the Kickstart mechanism is a bit on the loose side and you have to be careful on fitting it does not slip
Post  storkfoot on Wed Nov 08, 2017 9:40 am
Thanks, Ed. I have just found a couple of shims that are a decent fit so I’ll have a mess with them.
storkfoot
