Lui Assembly
Lui Assembly
Post  Creative Native on Sat Jan 06, 2018 6:00 am
Hi,
Is there a trick to removing / refitting the central tunnel section on a lui without having to remove the whole head assembly?
The scoot has just been re-painted and the final assembly is to fit the central section. However, my attempts so far have resulted in scratching the new paint work in various places trying to get the bloody thing into position Sad
Creative Native
Re: Lui Assembly
Post  looney tunes on Sat Jan 06, 2018 11:41 am
I have also come across this issue when doing a dry build.
From memory i think that I took out the headset bolt and block, which then gave me enough room to lift up the headset just enough to slot in the central beam.
Maybe there is a trick to doing it though that someone else knows.
Regards,
John
looney tunes
Centre Beam
Post  Admin on Tue Jan 09, 2018 3:13 am
In essence the only way to do it is to have the headset removed as it gets in the way.
Re: Lui Assembly
Post  daz.h on Fri Jan 12, 2018 10:17 am
as others have also said, i also put washing up liquid on the rubbers of the tunell, this allows it to slide down into posistion easier, start at the bottom and lower the tunell down, not the easiest of jobs on your own to do.
Re: Lui Assembly
