help wanted with wiring problem
Page 1 of 1 • Share •
im one small step away from an mot and then off to the dvla for a reg plate but when i connect the wiring from the headset to coil and flywheel end it keeps cuting out.
please help me
stevek- Guest
Re: help wanted with wiring problem
is the cut out switch damaged on the light switch?
daz.h- Posts : 866
is the actual switch screwed onto the handlebars, as this acts as the earth, so it needs to be.
daz.h- Posts : 866
wiring problem
the scoots stopping and starting on q with cut out button working just no lights or horn
help. daz h will post pics of crank for help with mag housing cheers mate steve.
stevek- Guest
horn might be knackerd, they often are, this is due to vibration, you can drill out the rivets, and look inside, mine had a solder that had come away from the coil, easy job, sorted in minutes.
do you have a wiring diagram?
daz.h- Posts : 866
Page 1 of 1
