j125 / tzr 150/ reed valve
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: j125 / tzr 150/ reed valve
Post  daz.h on Fri Sep 17, 2010 2:29 pm
just to say a HUGE thanks to simon for making this box up for me, its very much appreciated mate, and the workman ship is outstanding.
Post  Snails on Fri Sep 17, 2010 3:59 pm
That's brill
cheers
Post  littlemoon on Sat Sep 18, 2010 11:48 am
cheers cheers
phase 2
Post  littlemoon on Sat Sep 18, 2010 11:51 am
phase 2 of my project is about to get going very soon Cool Cool Cool , oh and cheers to daz for my shiny stuff Cool Cool
Post  daz.h on Sat Sep 18, 2010 3:31 pm
your welcome simon, been using that lathe on part 2
lathe
Post  littlemoon on Sun Sep 19, 2010 11:10 am
i will using my new lathe. first job will be a set of spacer bushes for the engine mounts in stainless steel. then a set of bushes for the rear shock in nylon, series 3 taffspeed conversion. then i will be re doing the packer plate, not happy with the finish on the mk 1 ( lack of machining knowledge). front wheel spindle needs drilling to fit the damper studs, oh and may be some stainless fork rods and cups. these will be the practice for the main event, the water cooled head.
carb
Post  littlemoon on Sat Sep 25, 2010 1:36 pm
new carb is on its way (oko flatslide 24mm power jet). also new hub Cool Cool
Post  daz.h on Sun Sep 26, 2010 3:26 am
fork rods and cups sound good, i will buy a set off you if you do them.
Post  littlemoon on Sun Sep 26, 2010 2:12 pm
daz.h wrote:fork rods and cups sound good, i will buy a set off you if you do them.
no probs. might have thought of a few other bits and bobs aswell.
Post  daz.h on Mon Sep 27, 2010 11:19 am
ohhh, do tell us bounce
new shiny stuff
Post  littlemoon on Mon Sep 27, 2010 3:35 pm
not yet Laughing
frame mods
Post  littlemoon on Sun Oct 03, 2010 2:35 pm
a bit of progress today.
made a frame stand today to mount the cometa frame onto whilst working on it. this will come in handy when fabbing up a legsheild tool box. the water pump, radiator and battery will live in the tool box Shocked Cool. i will put some pics up in a day or 2.
update of whats still to do
engine rebuild
crank pin and rebuild
legsheild tool box
cylinder tune
exhaust alterations
parts still needed
radiator
water pomp
engine rebuild kit
reed valve
tyres
cheers simon.
Post  daz.h on Mon Oct 04, 2010 1:41 am
good idea that simon, i had thought about making a bigger type frame to mount a engine in with brackets to mount electrics and a small petrol tank.
then under neath a set of rollers so that the engine once built could be started and then run in gear.
stuck for space at the moment, so will be another years project.
varitronic v af/vespa px
Post  littlemoon on Mon Oct 04, 2010 2:37 pm
i am now thinking the charging output from the varitronic wont be upto the job of powering a pump and maybe a fan. but i do like the idea of variable timing. so its back to the px conversion i think and an agusto type timing adjuster. i will run the varitronic on my lui 75 i think.
Post  littlemoon on Mon Oct 04, 2010 2:47 pm
daz.h wrote:good idea that simon, i had thought about making a bigger type frame to mount a engine in with brackets to mount electrics and a small petrol tank.
i have the full cometa mounted on this stand. but a frame for hanging an engine in to and being able to run the engine, that would be a good idea Cool Cool
Post  daz.h on Mon Oct 04, 2010 4:33 pm
Wink it would give them students a nice project Twisted Evil
Post  daz.h on Fri Oct 29, 2010 3:00 pm
hows it all coming along?
steady
Post  littlemoon on Sat Oct 30, 2010 2:38 pm
lathe trouble and a new job has slowed progress Sad . i cant seem to centre my self centering chuck, something wrong with the jaws. the lathe work i have done so far has been facing so being off centre has not been a problem. i need to enlarge the hole where the crank goes, which will need a hole saw 0f 85mm. i have ground some meat offf the big end of the rod. then i can rebuild the engine minus the top end. once i have this sorted i can do some better measuring of the top end, for the packer. i might put the legshields on tomorow and start the bread bin. i might get a bit more time on the project next week as i am covering for my dad running his workshop (cometa is there). i could also do with another starstream crank for measuring, i took measurments off my crank but another would be good to be absolutly sure. pumps and rads are easy to get, i know which ones i want. i could also do with a lth or jimmers reed valve or the loan of one to check fitment etc. i will update as and when i have made or lost progress. cheers simon. ps anyone else on with a wild conversion for their luna or j range ?. pps i think i have sussed the way forward for the lc head Cool
Post  daz.h on Sun Oct 31, 2010 4:17 pm
good to know you have sussed the lc head, i can not help with either the loan of a starstream crank or inlet manifold i'm affraid.
hope you sort out the lathe.
bread bin
Post  littlemoon on Sun Nov 07, 2010 12:46 pm
i started work on the bread bin ( with "v" duct technology Laughing ) today. here are a few pics
an this will be the rad i will be using
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160502680973&ssPageName=STRK:MEWAX:IT
i used the ancient art of gas welding to weld the box together,no filler wire was used. you cant beat the smell of burning luna paint Shocked Laughing
battery and pump
Post  littlemoon on Sun Nov 07, 2010 1:08 pm
i forgot to add, there will be enough room in the bread bin to locate the pump, regulator, ignition switch and battery
a bit more today
Post  littlemoon on Mon Nov 08, 2010 2:35 pm
a few more pics of the "v" duct
just a few brackets to make to mount the rad, pump and battery inside
Post  Snails on Mon Nov 08, 2010 2:45 pm
littlemoon wrote:i forgot to add, there will be enough room in the bread bin to locate the pump, regulator, ignition switch and battery
will you still get a full loaf in as well with all that other junk in there? Shocked
looking good!!!!
pump
Post  littlemoon on Sun Nov 21, 2010 3:49 pm
bought the pump tonite via ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330493442086&ssPageName=STRK:MEWAX:IT
radiator will ordered tomorow Cool
ther jobs
Post  littlemoon on Sun Nov 21, 2010 4:09 pm
i have started on the exhaust today. started making a new baffle as i did not get one with the exhaust. i will update with some pics i a day or two. cheers simon
