j125 / tzr 150/ reed valve
Page 4 of 4 Previous  1, 2, 3, 4
Re: j125 / tzr 150/ reed valve
Post  daz.h on Sun Nov 21, 2010 4:36 pm
pump looks good, a large turn over of liquid, which should help keep things cool.
rad
Post  littlemoon on Wed Nov 24, 2010 3:11 pm
bought this via ebay last night but still might go with the other. will have to see if it sqeezes in to be bread bin. oh, and the pump has arrived . very small and compact , genuine vag part. i will put some pics up tomorow night.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220695157972&ssPageName=STRK:MEWAX:IT
Post  daz.h on Wed Nov 24, 2010 3:40 pm
nice little rad, no need for seperate header tank.
re cap
Post  littlemoon on Thu Dec 02, 2010 4:52 pm
full engine rebuild kit ordered today including bearings, seals, clutch, you name it it was ordered.
parts all ready in stock
allspeeds exhaust
radiator
pump
ignition , choise of af/pk conversion or varitronic
front and rear hubs
tyres
nos mud gaurds and frame cover
seat
taffspeed rear shock
front dampers
bread bin
tzr piston kit.
yam rd rod
oko 24mm flatslide carb with needle and jet sets
still need lth reed valve ( could have this sorted soon)
jobs left to do
engine rebuild
finish crank
fab up brackets to mount the rad, pump and battery
water cooled head
re do packer
headlight rim( home made in stainless Shocked )
then dry build Shocked Cool
strip and paint
reg, tax, test , insure and snags
dyno Shocked Cool
parts
Post  littlemoon on Wed Dec 15, 2010 11:39 am
engine rebuld kit has arrived and reed valve. radiator is missing in action (due to snow Sad ) , but won another on ebay Very Happy . here is a pic.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160513328535&ssPageName=STRK:MEWNX:IT
hope this one makes it here
radiator + lth reed valve
Post  littlemoon on Sun Dec 19, 2010 6:37 am
radiator and reed valve are here Very Happy . even beter news is that the reed valve fits the stud spacing with no alterations. it will need tweeking in other areas though, as and when i get the cylinder tuned .
pic will be updated soon
lth reed valve
Post  littlemoon on Sun Dec 19, 2010 11:25 am
here are a few pics of the reed valve and barrel
the reed valve was altered by the last owner for their application. it needs a good polish
Post  Thackers on Sun Dec 26, 2010 9:47 am
I got a few Vega related things for Xmas one was a old magazine from Aug 88 with a liquid cooled, reed valve 150 lc Shocked Shocked engine done by M.B . The bike was called "tales of the unexpected" and cost around £2300 back then Shocked Shocked Shocked
Post  littlemoon on Sun Dec 26, 2010 12:12 pm
Thackers wrote:I got a few Vega related things for Xmas one was a old magazine from Aug 88 with a liquid cooled, reed valve 150 lc Shocked Shocked engine done by M.B . The bike was called "tales of the unexpected" and cost around £2300 back then Shocked Shocked Shocked
http://www.mbdevelopments.co.uk/archive/mag3.html
i think i have that mag. that conversion is far better than my contraption Laughing
Post  Thackers on Sun Dec 26, 2010 12:21 pm
That's the very one, i'm sure yours is just as good mate perhaps better i've seen some of the stuff your making and it looks bang on cheers
a few more pics
Post  littlemoon on Wed Dec 29, 2010 1:43 pm
a few more pics
Post  daz.h on Wed Dec 29, 2010 3:21 pm
good work simon, 10/10
rear shock
Post  littlemoon on Sat Jan 15, 2011 11:29 am
rear shock bushes are now done. taffspeed shock is being used Cool . i will put a few pics up soon
phaze 2
Post  littlemoon on Mon Jan 23, 2012 2:33 pm
well its been a while since i last did owt to me cometa, so with a couple of hours spare today i had a go at the cylinder
started opening up the transfers
then started polishing me dome
did a bit on the frame aswell, enlarging the holes where the cables pass through the frame
will be finishing the crank in the next week or so.
cheers simon
Post  NIGE on Sat Jan 28, 2012 4:37 am
NICE DOME. LOOKS GOOD SIMON.SO YOU ARE DOING ALL PORTING.YOU ARE VERY CAPABLE.
tuning
Post  littlemoon on Mon Jan 30, 2012 12:54 pm
as much as i would like to do the tuning i dont have the correct tools to do the job i only have a straight die grinder, so i think i will send it to mick abbey . i have done a few larger cylinders including an imola where i could get in with my die grinder . you need something like a dentist drill with a 90 degree head. i have allready gone too far on one off the transfers on my j cylinder it will need a spot of weld Embarassed .
Post  NIGE on Tue Jan 31, 2012 1:46 pm
SHAME THAT SIMON .WHAT LEVEL OF TUNE ARE YOU GOING FOR .QUITE HIGH BY THE SIZE OF THOSE NICE TRANSFERS.ITS NICE TO SEE A MODDED CYLINDER.I WILL BE SENDING MINE TO MICK ABBEY .DEPENDS ON YOUR TUNE I MIGHT HAVE EXACT SPEC.IF YOU DO NOT MIND HAVING YOURS DONE FIRST
very interesting post
Post  littlewilly on Sun Mar 11, 2012 10:48 am
Hi, I am a new member and your post is the first one that caught my eye, it all looks very interesting and I can't wait to hear how it goes but I thought I'd mention that if you only want a reliable 60 MPH
it seems way over the top, I used to have A racing J 125 which had no after market items on it.
Though it only had three gears and very little tuning to the barrel (as per Ken Herlingshaw's performance and tuning manual) just 3 mm from inlet, standard silencer and A 20mm -SX200 jetted carb & manifold.
this gives about 65 MPH but the biggest boost is the machined LI 150 head, which pushes top end
up to 75MPH.
finally a warning although my J was utterly mechanical reliable and as fast as most 200's you may need
to carry A pocketful of spare condensers as the standard type cant take the revs reliably.
Looking forward to the next instalment on this post's topic, many thanx.
littlewilly
Post  NIGE on Sun Mar 11, 2012 1:47 pm
hi .thats useful info .i am having a li head done .have just given it to somebody to plug holes up.my barrel is going to chiselspeed now after contacting martin cooke.he came back with all the relevant info whereas others were not able to and could only do part of the job.
Your most welcome
Post  littlewilly on Fri Mar 16, 2012 1:11 pm
I should mention that the inlet manifold should be 150 or 125 SX type for SH20 or GP150 for SH 22 -
this also needs the stud holes re-drilled too - but if the exhaust is opened up more than just polishing (widening a little's OK) - you end-up losing it all (big time) tell who ever does it to beware - the good thing about this is that by not using a reed - you get twice the MPG and the power band is very flat all all the way through too and who knows with 4 gears you should crack 80MPH - best of luck with it Wink
Last edited by littlewilly on Fri Mar 16, 2012 1:41 pm; edited 1 time in total (Reason for editing : more thoughts)
littlewilly
p.s
Post  littlewilly on Fri Mar 16, 2012 1:50 pm
I seem to remember the head has to be machined for a short reach plug - the accessibility is a bit of a bitch with the plug at the back but it's a price worth the paying
littlewilly
