Difference between cranks and mag housing
Post  Jools on Sat Oct 15, 2011 5:57 am
Hello all,
I believe there are two types of cranks for the Vega 75, early and late and two types of mag housing to suit each crank.
Part No. 20050014 (needle 3 part roller bearing type mag housing) early?
Part No. 20950045 (single ball bearing type mag housing) Late?
How can you tell what type of crank you have and which mag housing suits it. I've been trying to find this info out for a while now.
Cheers all.
Jools
Re: Difference between cranks and mag housing
Post  Thackers on Sat Oct 15, 2011 12:23 pm
Jools, take a look here
http://forums.lcgb.co.uk/phpBB2/viewforum.php?f=3&topicdays=0&start=25
It might take a while to sift through the thread headlines but i'm sure you will find some answers to your question
Post  daz.h on Sat Oct 15, 2011 5:21 pm
its easy, look at your crank (the threaded end) follor the shaft to the main body towards the last inch is it all the same width? if yes then its the 3 part mag housing if not, then its the 1 piece bearing
Post  Thackers on Sun Oct 16, 2011 3:35 am
Spot on photo that Daz, you sure you dont want to do a Luna book study
Post  Jools on Mon Oct 17, 2011 7:29 am
Nice one Daz, thanks for that, I've never been able to find information on the cranks I dont suppose you know the Innocenti part numbers for the two style of cranks?
Jools
Post  daz.h on Mon Oct 17, 2011 1:30 pm
off hand i dont think i do, but i will look later.
Post  daz.h on Mon Oct 17, 2011 1:34 pm
mag housings,
