vega mag question
vega mag question
Post  wrekkah on Sat Dec 31, 2011 5:32 pm
Hi guys, vega noob here.
working on a vega engine that came to me in pieces. I have the mag style shown on the left
can someone tell me the bearing number and seal types needed for this particular mag flange type?
Thanks
wrekkah
Re: vega mag question
Post  daz.h on Mon Jan 02, 2012 4:22 pm
hey, thats my old picture. youre quite welcome to it though Very Happy
save yourself time and hassle and buy one from scooter restorations, they are listed under the j range.
Post  wrekkah on Mon Jan 02, 2012 7:51 pm
Thanks I grabbed it from this site. Very Happy
Just want to make sure I get the right flange for the crank I have.
There was a new mag flange in the box of bits (no bearings or seals) but I think it is the needle bearing type. The crank is the later style that goes with the ball bearing mag type.
I saw the assembled mag flange on the Scooter Restorations site. It doesn't mention which type it is.
I'm on the other side of the pond so I was hoping to source the bearings and seals locally.
I just went through every post on the LCGB and the archive LCGB in the Lui/Luna/Vega sections. Learned a lot!
Cheers,
Aaron
wrekkah
Post  daz.h on Tue Jan 03, 2012 4:49 pm
the mag flanges on scooter restorations site will be the 3 part needle roller bearing, the type on the left of the picture.
Post  Innocenti-71 on Wed Jan 04, 2012 1:36 am
The needle bearing is from German manufacturer INA and quite a rare (expensive) version.
Type is: NAO 20-37-16 so measurents are 20x37x16mm.
Innocenti-71
View user profile http://www.lambretta-club-deutschland.de
Post  wrekkah on Wed Jan 04, 2012 4:02 pm
So are the ball bearing type mag flanges available? or...are the cranks that use the needle bearing style available?
Are we talking rocking horse poo?
Any leads would be appreciated. I've struck out in my search so far.
Thanks
wrekkah
Post  daz.h on Wed Jan 04, 2012 4:11 pm
neither the ball bearing type mag flange or either of the cranks are readily available.
i have the part number (somewhere) for the bearing for the single pice ball bearing .
Post  Innocenti-71 on Thu Jan 05, 2012 1:09 am
Innocenti-71
Post  wrekkah on Thu Jan 05, 2012 7:12 am
Thanks!
That looks like the correct housing.
Hope they actually have them in stock.
I assume that is the outer seal, so is there no inner seal (against the crank)?
wrekkah
Post  Snails on Fri Jan 06, 2012 2:55 am
Hi, if you need the rare mag flange I have one spare so drop me a pm
Post  wrekkah on Fri Jan 06, 2012 7:17 am
Thanks Snails, that's a very kind offer.
I'll let you know.
wrekkah
Post  wrekkah on Wed Feb 01, 2012 7:10 am
Finally have the proper mag housing, bearing and outer seal....Thanks Snails!!!
One question, is there anything that fits between the crank and the mag bearing? A seal or other part?
There seems to be a lot space. The earlier style mag housing with the two piece bearing has an inner and outer seal. If there is no part is seems strange they would change the design so radically. Does anyone know the reason???
Thanks
wrekkah
Post  daz.h on Thu Feb 02, 2012 5:13 am
similar type bearing on the gp, it is petrol/oil lubricated.
