latest project
Page 1 of 7 1, 2, 3, 4, 5, 6, 7  Next
latest project
Post  daz.h on Mon Jul 12, 2010 8:57 pm
well, this project has been several years in the pipeline, due to the sourceing of parts, other projects, family commitments, oh and work.
its my take on what i think might have happened to the luna line had the innocenti factory continued for a while longer.
as i'm sure most are aware that towards the last of the gp200 run they introduced a electronic set up, along with a special seat for the uk models.
also the gp's and the lunas that were shipped out to australia were fitted with indicators, some of these models stayed in this country.
so i intend to build a electronic vega, along with a similar seat to the gp200 electronic and then fit other parts that i think would have eventually got fitted as standard, these been a lesheild tool box and front dampers on the forks.
i had a old motor and was lucky enough to be given a old frame by pete davies (luna chairman) only to find that there were only about 56 numbers away from each other Shocked
the frame needed a new rear strut and other little bits of welding here and there and it was the frame with the clamp on steering lock, just my luck Evil or Very Mad i had three bolt on ones and could i find a clamp on one...... no, well not for several months, got a key cut by jem, and its all waiting to be fitted to the frame once its painted.
so here are a few pics to be going on with.
Re: latest project
Post  daz.h on Mon Jul 12, 2010 9:16 pm
hope you like it so far.
not sure if you can see, but these were new unused legsheilds and had the tooling marks where the old type badges had been previously fitted.
the old seat after stripping.
new seat cover and foam in electronic style.
bread bin
Post  littlemoon on Mon Jul 12, 2010 9:41 pm
very nice. i like the bread bin Cool whats it off ?. oh and the seat Cool. with the indicators where does the flasher unit live and does it have a different bulb holder/connector block?. cheers simon
Re: latest project
Post  daz.h on Mon Jul 12, 2010 10:02 pm
bread bin was from asda Very Happy a friend of a mate who is a fabricator made it up for me.
the original flasher relay i belive is situated in the headset of all places, and you thought it was already a tight squeeze.
with going to 12 volt i'm tempted to use a vepa one i have spare and locate it in a better space.
as for the connector block i'm unsure, i have a indicator diagram somewhere so will have to check it out.
making a loom will be fun...........NOT Mad
Re: latest project
Post  Snails on Tue Jul 13, 2010 7:43 am
Love the glove box Daz, and the seat. Bet you would of have lots of takers (by luna standards) if you could get either remade in numbers. Especially the glove box as who does not need better luggage carrying ability on their luna?
Re: latest project
Post  daz.h on Sun Oct 10, 2010 4:26 pm
well, quite a bit more has happened since my last post, i have now finally got a indicator switch cheers and a big thanks to staffy who informed me of it Smile
also i cant fail to mention littlemoon who has done a fantastic job making up a metal toolbox to go under the petrol tank and also fabricated and fitted frame strengtheners where the frame had been cut. and also modified my rear mudguard with a extra clip for me Like a Star @ heaven
hiswork can be seen here.
http://lunaownersclub.lifediscussion.net/tuning-conversions-f7/j125-tzr-150-reed-valve-t20.htm
the frame and associated parts are now all filled and in primer and was given a guide coat just after these pics were taken, fingers crossed i should be getting some painted parts back shortly, from carl a mate who paints my scooters, when it comes to been fussy and a perfectionist, he's it. Twisted Evil
Re: latest project
Post  littlemoon on Sun Oct 10, 2010 5:13 pm
daz.h wrote:well, quite a bit more has happened since my last post, i have now finally got a indicator switch cheers and a big thanks to staffy who informed me of it Smile
looking good daz, what colour is going to be ?. have you made any progress with the indicator wiring conundrum. i have made a bit of progress myself, today.
Re: latest project
Post  Staffy (Gareth) on Sun Oct 10, 2010 7:47 pm
looking very interesting this one, can't wait to see the indicators fitted and to hear how the electrics get on. Might have something interesting for you so check your PM Cool
Re: latest project
Post  daz.h on Mon Oct 11, 2010 8:28 am
simon colour will be yellow ochre, reason been is that i have a load left over from when i got my gp painted.
as for the wiring set up i have bought from kempys a 2 pin flasher relay, and they gave me a colour copy of a 12 volt electronic, with indicators and no battery set up, wiring diagram, so i will follow that......... somehow Mad
i have therefore removed the junction box from the lid top you made and had the two holes welded up, i have had to remove some of the spine you grafted on as the flasher relay is at a awkward angle and only sits in on the very middle and needs to be bolted in, and the spine was in the way.
i will be off to auto jumble in november to get my miles and miles of wire What a Face
staffy thanks for the pm mate Smile
Project
Post  Admin on Mon Oct 11, 2010 9:46 am
Daz - looking good mate, glad you could put that old frame of mine to some use Very Happy
Re: latest project
Post  daz.h on Mon Oct 11, 2010 6:15 pm
guide coat on, now to flat it all down Sad
Re: latest project
Post  daz.h on Sun Oct 24, 2010 8:35 pm
wet flat now completed, now ready for some colour Very Happy
crank is in the motor, along with new jap rod from chiselspeed.
casing has been fitted with stainless studs around the side casing, chain guides and the magneto plate wiring plate, the small screws in the mag plate are notorious for seizeing in and snapping Evil or Very Mad
finally, the piston, a 50mm malossi job from taffspeed, the carb has been bored out to just short of 22mm by ian frankland and he was also responsible for the tuning of the cylinder, should be a little quicker than standard, i think cc wise it will be around 85, i'm sure someone will have the correct method of calculating it.
Re: latest project
Post  daz.h on Wed Nov 24, 2010 10:52 pm
well, got more done over the last few days, some head scratching moments and plenty of cursing Mad
up rated clutch springs, lots shorter than vega length, and too wide to sit correctly into the spider recess.
plenty of messing round trying to get squish correct, ended up at 1.2mm with no gaskets Neutral hopefully wont be a problem as head is doweled in 2 places and will be using a 2mm packr plate.
Re: latest project
Post  daz.h on Wed Nov 24, 2010 11:15 pm
ports matched up, exhaust gasket was way too small as was inlet, both now match.
cylinder top with dowels.
piston at botom dead centre, exhaust and transfers open
Re: latest project
Post  daz.h on Wed Nov 24, 2010 11:20 pm
put flywheel on and tried on plastic flywheel cowl which was rubbing, had to sand this down as did not want it to melt or cause more head scratching scratch
set up to check for top dead centre.
top dead centre now achived, arrow for tdc is now at the bottom of casing due to using electronic flywheel.
