Indicator Info
Indicator Info
Post  siobhanellis on Sat Apr 28, 2012 7:10 pm
Here's some pics from a very dilapidated Australian Vega that I'm stripping. However, it is unmolested, so shows some very useful info for how the indicator set up was done.
Just for a laugh, thought you may want to see what the scoot was like. This actually makes it look good!
Inside the headset. You can see the Indicator Relay all wrapped up in Black Insulation tape. Such a high quality job.
The headset top. You can see where the foam sleeve was created and attached for the indicator relay.
The indicator relay with the insulation tape removed.
The cables coming out of the switch, going down the side of the handlebars.
Re: Indicator Info
Post  daz.h on Sun Apr 29, 2012 3:42 pm
great reference pictures siobhan, thanks for sharing them with us.
