kick start shaft
kick start shaft
Post  NIGE on Tue May 22, 2012 12:34 pm
just changing kick start shaft .no o rings on old one .is there just one o ring needed .the one nearest spline end i know.but do you put one on the other end because there is a small grove which as got me thinking you might need two .
Re: kick start shaft
Post  wack 63 on Mon Jul 16, 2012 2:45 pm
Just the one if memory serves me right.It does the job provided the casing bushes are ok.
Post  NIGE on Mon Jul 16, 2012 4:29 pm
thanks wack .i have only put the one on.side case is nos so bush is good .cheers
