Using the RD 80LC Barrell etc
Post  Admin on Thu Feb 07, 2013 8:27 am
As Daz H mentioned it in another post what are the pros/cons etc of using the RD 80 LC barrell etc. In fact which parts would you need - new barrel, piston, cylinder head? How radical would the gearing have to be changed etc.
Any ideas would be appreciated. Very Happy
Re: Using the RD 80LC Barrell etc
Post  daz.h on Thu Feb 07, 2013 3:58 pm
they were good for 80mph so thats a pro, yet very economical.
several firms also do conversion kits for these to around 110cc, the cylinder is quite small and compact.
i think they were a 42mm stroke, so using a vega crank would give extra cc's
cons fabrication would be required, welding etc
Post  itsjoeyfontane on Tue Mar 19, 2013 5:27 pm
...here's an idea i've had..? what about using the rd reed valve piston in a casa alloy barrell ? I think its the same bore ..? can't remember or spell dimensions..lol... and adding a reed valve...
not had time to follow this idea up...the skirt length and hole size in piston may be an issue...? Shocked
RD 80
Post  Admin on Wed Mar 20, 2013 10:19 am
Good thinking Joey - I live near to the tuner Harry Barlow (of Pro Porting fame) he's a Yamaha as well as Lambretta tuner so I'm going to quiz him on this one
Post  daz.h on Mon Mar 25, 2013 1:50 am
let us know how you get on.
Post  itsjoeyfontane on Fri Apr 12, 2013 2:11 pm
..any progress here..?
RD Barrell
Post  Admin on Thu Apr 18, 2013 5:10 am
Trying to pin Harry Barlow down is harder than trying to pin me down sometimes Very Happy So far no joy Very Happy
Post  itsjoeyfontane on Thu Apr 18, 2013 7:34 am
..just need to find out the depth of the skirt from the pin centre and how much skirt from the windows to the base as I have a feeling it might have to cut to fit...?
Post  itsjoeyfontane on Wed Apr 24, 2013 10:14 am
... does anyone know what the clearance gap measures between the piston skirt and the crank webs at bdc...from my guesstimates the rd piston looks good -4mm off skirt.. Leaves about 4mm from skirt bottom to port window hole.....? study
