Vega 'fast flow' fuel tap
Post  tonyicon on Fri Feb 15, 2013 4:50 am
Does anyone have any thoughts on the standard Vega fuel tap. Does it have a high enough flow for a tuned motor? Can it be 'rebored?' Are there any alternatives?
tonyicon
Re: Vega 'fast flow' fuel tap
Post  daz.h on Fri Feb 15, 2013 4:05 pm
good question, i stripped an old tap down many years ago, and from what i recall theres not much that can be done, i'm sure there will be something suitable outhere, just needs finding, .
Post  Snails on Wed Feb 20, 2013 3:58 pm
Anyone remember that TS1 Vega? Now I bet that drank petrol. If it had a Vega tank on the back end and from memory I think it did then the chap who made it should be able to give you an answer. Cant remember his name but he used to be on LCGB forum. Just an idea Smile
I need to know the answer myself so if you do find out let us know Wink
Post  daz.h on Thu Feb 21, 2013 4:16 pm
darrell miles /mills or something like that
Post  Snails on Sun Feb 24, 2013 12:16 pm
that's him Smile
Post  itsjoeyfontane on Tue Mar 19, 2013 5:17 pm
...yes i need one...i've drilled mine out and fitted a s3 f/f main flow tube and dilled all the internal oriffices...better but it now leaks?...not an ideal solution but it s sorted fuel flow out...I was going to look down the italian motorcycle/race strada....?
Post  robd on Fri Apr 12, 2013 2:02 pm
The guy who built the ts1 Vega was Mark Gray. He is a welding wizard so may have swapped out the tap spigot for a S3 one. I'll ask him and find out.
robd
Post  Thackers on Tue Oct 08, 2013 11:49 am
Any further news on this subject? I suspect the hole in the tank for a standard tap will be too small to fit most taps out there, plus it sits so close to the frame. I wonder if you could have a threaded adaptor that screws into the tank with a nut below to tighten onto a tap. Would a standard flow tap be quicker than a standard Vega tap?
I think this could be a worth while upgrade especially for the tuned up brigade.
Anyone invented a fast flow yet???????????????Exclamation Exclamation Exclamation
Post  Thackers on Sat Oct 17, 2015 1:48 am
So it's been awhile since I first posted asking the question on a fast flow tap. Has anyone come up with a solution?
Post  daz.h on Mon Oct 26, 2015 7:42 am
you'll definitely be needing something that flows more than standard thackers
