Centre beam fixing and more!
Post  Snails on Wed Jul 31, 2013 6:14 am
Hi
I'm trying to buy all my fixings preferably in stainless steel
Can anyone tell me what fixings are used to secure the centre beam at the bottom? They don't appear to be threaded holes in the frame but I can't see a way to use a nut and bolt.
Also I'm thinking of using stainless bolts for the head set clamp and fork links. Does it matter if the thread runs the whole length of the bolt?
Re: Centre beam fixing and more!
Post  Scooter Paul on Wed Jul 31, 2013 10:02 am
Hi, I think they are self tappers! with a cup washer on top but a rubber washer between the cover and the raised bracket underneath - very fiddly to fit the rubber washer unless you fit the screw, cup washer and rubber washer and then offer it all up sort of pre assembled.
Post  Snails on Wed Jul 31, 2013 1:44 pm
Thanks Paul. Think you are right as that's what I had fitted when I dismantled but thought the self tapers was some sort of bodge
Post  NIGE on Wed Jul 31, 2013 3:35 pm
HI SNAILS YOU NEED TO HAVE A SHANK ON THE BOLT A COMPLETE THREAD IS NOT STRONG ENOUGH
