6v horn harness(black wire)
Post  li mick on Sun Apr 06, 2014 8:49 am
just looking at fitting harness to my lui,the harness has only one wire going to the horn (twin brown),it looks as though i should run a black wire to the light switch but i cant see where it could go,as all the wires from the switch i have going to the light junction connector can anyone tell me if this is correct.thanks mick.
Re: 6v horn harness(black wire)
Post  daz.h on Sun Apr 06, 2014 1:59 pm
from memory there should be a long black wire down to the horn.
the double brown goes into the horn, then up to the light junction box and then provides power to switch.
6volt horn (black wire)
Post  li mick on Sun Apr 06, 2014 5:18 pm
thanks daz,i have the double browns sorted and i have took a black from the other horn terminal but its where the other end of the black wire goes i am not sure of,i thought it must be to the switch or it could be to earth ?
Post  daz.h on Mon Apr 07, 2014 9:29 am
is there not a long black wire from the switch ?
horn wire(black)
Post  li mick on Mon Apr 07, 2014 10:44 am
i only have one black wire coming from the light switch that i have put to the headlight connector,should there be two blacks from the light switch?
Post  daz.h on Tue Apr 08, 2014 6:48 am
never had a lui switch, but from looking at a 50 manual, the diagram shows two wires
horn black wire (lui)
Post  li mick on Tue Apr 08, 2014 5:34 pm
any chance of copying the diagram daz?
Post  daz.h on Wed Apr 09, 2014 10:45 am
[img][/img]
Post  daz.h on Wed Apr 09, 2014 10:46 am
Post  daz.h on Wed Apr 09, 2014 10:47 am
hope they help mick.
Post  li mick on Wed Apr 09, 2014 5:07 pm
thanks daz i hope to have a better look at the week-end.
Post  Snails on Thu Apr 10, 2014 3:56 am
Hi Mick
If you get really stuck I still have my old loom knocking around the garage somewhere I can try and compare mine for you.
Post  daz.h on Thu Apr 10, 2014 8:04 am
there are several pics on Google of the said switch, it does show one long wire that is white with a black sleeve and a flag type terminal which would go to the horn.
lui horn
Post  li mick on Thu Apr 10, 2014 1:18 pm
daz i think that the white wire with the black sleeve on it is the one for the horn,when i had the lui there were no connector ends on the light switch wires so i put the bullet type ends on them all not knowing about the different end on the sleeved white wire,at least that is where i will put it for now.thanks for your help.mick.
Post  daz.h on Fri Apr 11, 2014 8:03 am
Very Happy happy to help mate.
