Wiring Loom
Wiring Loom
Post  Adam Sleight on Sat Jun 21, 2014 4:08 pm
Can anyone please post a picture of how they have placed their wiring loom and junction box on their bike please?
Adam Sleight
Re: Wiring Loom
Post  Snails on Sun Jun 22, 2014 1:44 am
On a lui the junction box is part of the flywheel cover. An odd and crap idea but there you go
Re: Wiring Loom
Post  Adam Sleight on Sun Jun 22, 2014 4:02 am
I know about that but I've put a 75 flywheel and stator on mine with a 75 wiring loom and junction box. So was wondering how people have routed their looms
Adam Sleight
Re: Wiring Loom
Post  Snails on Sun Jun 22, 2014 10:26 am
I have images that show correct routing that I used for reference. I'll try to find them for you.
Basically from the headset down frame tube above frame struts. Through frame tube and out via rear mudguard to junction box.
There may be some photos on my Show your ride' thread if you don't want to wait although my loom was custom made so my junction box is mounted inside the frame rather than exiting via rear mudguard.
Re: Wiring Loom
Post  Adam Sleight on Sun Jun 22, 2014 3:12 pm
I'll wait then if that's okay because I have my junction box mounted to the underneath of the frame (above the engine)
Adam Sleight
Re: Wiring Loom
Post  Snails on Mon Jun 23, 2014 12:32 am
Same principle as exit via mudguard but send me your email address and I'll fw on.
Re: Wiring Loom
Post  daz.h on Mon Jun 23, 2014 5:31 am
Adam, I don't wish to be a bearer of bad news, but make sure your frame has the hole for the loom to pass through, I had an early lui frame many years ago, and it did not have the coil brackets on, neither did it have the hole for the loom to pass through, just a small slot which I had to drill out.
the hole is in the lower middle of the frame section where the engine mount bolt goes .
Re: Wiring Loom
Post  Snails on Mon Jun 23, 2014 9:21 am
The hole Daz is talking about is round and about 10mm as compared to a smaller less rounded hole that my frame also has by which it possible to thread wires to the back light but which is not big enough for a loom
Re: Wiring Loom
Post  Adam Sleight on Wed Jun 25, 2014 4:33 am
The panic is over Wink my frame has the large hole and the small one. We used an old speedo cable to pull the loom through the frame and out of the hole. Worked a treat. Thanks for your help
Adam Sleight
Re: Wiring Loom
