disc brake conversion
Post  boozee on Thu Oct 09, 2014 12:04 am
has anyone out there done a front disc brake conversion using the origonal forks and hub.
Re: disc brake conversion
Post  Snails on Thu Oct 09, 2014 5:12 am
I have seen it done but very rarely. Think I may have a picture on my laptop at home. I have a feeling it was a custom built hub
disc
Post  boozee on Thu Oct 09, 2014 7:00 am
seen one on green custom vega on youtube (lambretta vega 135) its had the bottom off series 3 welded to the top of vega forks, looks good but would prefer to use vega hub.
Post  Scooter Paul on Thu Oct 09, 2014 7:31 am
boozee wrote:seen one on green custom vega on youtube (lambretta vega 135) its had the bottom off series 3 welded to the top of vega forks, looks good but would prefer to use vega hub.
The Rimini prepared one used in the Beamish trial this year had a similar set up.
Post  wack 63 on Fri Oct 10, 2014 2:32 pm
I've seen one on a white Vega and the one I did (red metalflake Lui). I made a disc carrier to fix to the original hub and a caliper plate similar to a ScootRS Ser 3 one.Probably overkill but I wanted to see if it could be done.
disc.
Post  boozee on Fri Oct 10, 2014 4:29 pm
i,d like to see a pic of that if you have one.
Post  wack 63 on Fri Oct 10, 2014 4:58 pm
disc
Post  boozee on Sat Oct 11, 2014 1:18 am
that looks awesome, do you fancy doin one for me. are you using fully hydraulic or a cable to aremote cylinder.
Post  Snails on Sun Oct 12, 2014 1:18 am
I dont know anything about this scooter unfortunately
Post  Snails on Sun Oct 12, 2014 1:29 am
This is the one of the green TS1 vega. Love how they sorted the mudguard issue
Post  Snails on Sun Oct 12, 2014 1:34 am
wack 63 wrote:
That is fine work. You should go into production!
I know people say that a lo about Vega parts but who would not want a disc brake for their scooter!
Ok so anyone into originality maybe not, but who else?
disc brake
Post  itsjoeyfontane on Sat Nov 01, 2014 3:34 pm
..Wacks brake looks like a work of art..but I've found that the 'sunny hub' reverse pull will stop you quicker than a parked car... Laughing
