Cento barrel and Piston and 12V conversion
Post  timthemod on Mon Dec 01, 2014 8:37 am
Newby on here!
thinking about doing a basic cc upgrade to 100cc using Cento barrel and piston, is this possible and also are there any downsides?
Also looking at 12v conversion using SIL Sunny stator and flywheel, anyone done this?
Parts from Scooter restorations seen fairly cheap.
Thanks
timthemod
Re: Cento barrel and Piston and 12V conversion
Post  Thackers on Mon Dec 01, 2014 11:24 am
Not too sure on the 12v conversion, I think most of these have been done using a lightened flywheel and converted stator using a cdi unit and regulator, mine was done that way.
As for the Cento barrel etc someone on here will tell you if it can be done or not, but I'm doubtful somehow. Have a good look in this section you might find your answers within a post on a different subject. Very Happy
Post  daz.h on Tue Dec 02, 2014 3:18 pm
tim, the cento uses a different bigger piston and small end bearing to suit the crank, you can not just put a cento cylinder straight on the vega or lui casings.
the 12v conversion is an ok idea, but vega lights etc are still fine at 6 volt, and I think the stators will still be using points, either get one of the new electronic kits or get jem booth to machine you a af lightweight flywheel and use the parts from a vespa pk stator.
cento conversion
Post  itsjoeyfontane on Tue Dec 02, 2014 3:34 pm
..bite the bullet and get a Parma 80 kit and lunatronic ignition.....
