Luna 50 --> 80 conversion what is needed to convert to 4 speed gearbox
Post  mviszek on Sun Jan 04, 2015 5:24 am
Hi guys,
Last year we have upgrated our Luna to 75 (80 I guess). The cylinder and piston, chain, clutch, bearings have been changed. Girl from our club drove on this Luna all ride out route on last years Eurolambretta in Davos. Who was there know how hard this ride out was. We're planning winter projects now. The Luna seems to need 4th gear. Please let us know in the detail what is needed to convert?
many thanks in advance,
Maciej
(KKS Przygoda Club, part of Lambretta Club Poland, Warsaw, Pland)
mviszek
Re: Luna 50 --> 80 conversion what is needed to convert to 4 speed gearbox
Post  Scooter Paul on Sun Jan 04, 2015 5:58 am
I don't think a 4 speed box will fit. In fact I'm sure. Most people fit a 15 tooth front sprocket and I think Rimini Lambretta have a gear cluster upgrade. I've not done either conversion but as I have a 50 too and will probably fit a 75/80 kit I'd be interested in any feedback. Does the 15 front sprocket need a longer chain or will the standard one fit?
4 speed
Post  lunaloon on Mon Jan 05, 2015 8:06 am
You can upgrade Lui 50 to 4 speed but you will need all the 75 gears,output shaft,wider endplate,chainwheel sprockets,clutch,Crankshaft and the 75 chaincase cover [basically everything from a 75] not really worth it and very costly if you can get the parts! best thing to do is what scooterpaul suggests upgrade front sprocket or gearing speak to Rimini Lambretta or Dan at scootopia Weston-super-mare.
lunaloon
RE
Post  mviszek on Tue Jan 06, 2015 1:15 pm
Thanks guys. I have J125 one. What can be sources from that engine to convert to 4 gears box?
mviszek
Post  Snails on Wed Jan 07, 2015 3:34 am
That will only work if its a 4 speed Super Star Stream
Lui 50, Cento and J125 are interchangeable
Vega 75 and 4 speed Super Star Stream are interchangeable
You cant mix the two.
If its a J125 3 speed engine that you have you could swap all the internals from that and get rid of the 80 kit......
.....but by far the easiest thing to do is buy the new front sprocket from Rimini Lambrettas as its been designed to fix the issue you have
