Latest Project
Page 1 of 4 1, 2, 3, 4  Next
Latest Project
Post  trotsky on Sun Jan 18, 2015 2:06 pm
Finally starting to get somewhere with the Vega. Frame gone away to painters, powder coated, polished & chrome parts are back.
Here are some Pix of the assembled Sunny Hubs & work starting to mount the Rev counter/Speedo i'm using ...
Re: Latest Project
Post  li mick on Sun Jan 18, 2015 3:07 pm
now that looks the part! well done that man.
Re: Latest Project
Post  mickey c on Mon Jan 19, 2015 1:12 am
that speedo / rev counter mod looks ace!
do you mind me asking what it is, it looks quite shallow in your photos - I am thinking of doing something similar with a SIP digital speedo but these are quite deep and took some squeezing into my series 2. I don't fancy the chances of getting one in a Vega headset with building it up loads.
Re: Latest Project
Post  Snails on Mon Jan 19, 2015 4:27 am
Yeah love the speedo
Re: Latest Project
Post  trotsky on Mon Jan 19, 2015 3:19 pm
Cheers. Hi Mickey, it's an Acewell MD52 302, it's a 52mm diameter gauge. I wanted a Rev/speedo all in one. Koso do nice 52mm Gauges but not all-in-one units, so I plumped for this one. It's still quite deep but will fit - though it will be busy in the headset!
I have had to dremel out the inner ridge where the speedo goes, it now drops nicely into the hole & i cut the studs off & the plastic screw down. The only issue is the bezel sat on the slopes on the headset top, so I had a spacer made to lift & cure this. Now Aroldited on, when filled & painted it should look "S-Type stylee!!"
I also had to dremel wider the headset base where the cables go thru to accommodate the plugs, no issue as there is plenty of meat. I'll change the Blue plug with a 2 pin one, as i won't need all the gadgets on it. Using Varitronic ignition, so should have no power feed issues.
Re: Latest Project
Post  mickey c on Tue Jan 20, 2015 1:45 pm
As I say fella, that looks awesome (as my teenager would say). The ace well looks really good but variatronic is out of my budget so sticking to SIP digital speedo in a spare headset I have. Would you mind me asking who made your spacer please? I'll need 1 of them too.
Re: Latest Project
Post  trotsky on Tue Jan 20, 2015 3:20 pm
Hi Mickey, I'm sure a SIP one will look the part. Lads at a place I deliver to did a guvvy job for me. Any small engineering shop with a lathe will be able to do one if you take all your parts into them.Good luck....Steve
Re: Latest Project
Post  Snails on Wed Jan 21, 2015 12:33 am
Does the SIP one not need power too?
Re: Latest Project
Post  mickey c on Wed Jan 21, 2015 2:00 am
Cheers Trotsky
there's a few firms near me, i'll make some calls.
Hi Ed
the SIP one does need power (obviously) but they work AC and can just take a feed from the loom, I think I found a feed from the LT worked well on my Li but think I had to do that because its DC.  A feed from the lights should be fine.
Re: Latest Project
Post  trotsky on Sat Jan 24, 2015 10:04 am
Bit more done today, 4 plate clutch dry-built & Jockeys Chain Slipper in situ. Stuck with motor for now as waiting for Martin@Chiselspeeds wrists to heal after his Op on them as he's not able to do my head at the moment.
Not a problem though as hopefully everythings back from the painters next week  cheers .
vega
Post  lunaloon on Sat Jan 24, 2015 10:52 am
smashing job your doing Trotsky well done that man! Very Happy whats the motor spec ?
lunaloon
Re: Latest Project
Post  trotsky on Sat Jan 24, 2015 11:05 am
Cheers Lunaloon, 140ish using 60.5mm KH500 piston, tuning re-tweeked by a mate (DSC Scotty), 26mm PHBH Dellorto with Mini Atomic Reed Valve, Starstream Crank & Gearing, 4 plate Clutch, Varitronic & Chiselspeed Pipe. Won't be a world-beater, but should be good for a smooth steady 50-55 & fun to ride!! Razz
Re: Latest Project
Post  Snails on Sat Jan 24, 2015 11:12 am
What modifications did you need to make to fit the clutch?
vega
Post  lunaloon on Sat Jan 24, 2015 11:18 am
Nice spec motor as you say no world beater but respectable speed,
Really looking forward to seeing it being put back together whats the plan on the paintwork side of things.
cheers Wink
lunaloon
Re: Latest Project
Post  trotsky on Sat Jan 24, 2015 11:38 am
Cheers, yeah looking for good torque so enjoyable to ride. Again nothing wild, straight Ochre & a bit of chrome. A few nice simple alterations to the frame, wheels & fixtures.... straight & subtle Wink
Re: Latest Project
Post  daz.h on Sun Jan 25, 2015 4:23 am
wow, a great start to a very promising project, well done.
Re: Latest Project
Post  trotsky on Sun Jan 25, 2015 8:32 am
Cheers Daz Embarassed  Just really looked at all the various ideas & things people have done over the years, then along with my own idea of what I like, put them all into this one, hopefully keeping it simple looking & un-fussy....
vega
Post  lunaloon on Mon Jan 26, 2015 11:06 am
Nice colour ochre [but not everyones taste] keep up the good work Wink
lunaloon
Re: Latest Project
Post  Scooter Paul on Tue Jan 27, 2015 12:56 am
Simple and un fussy always works for me too. In my opinion, for what little it's worth, many scooters are spoilt by making them over complicated. But there again different strokes for different folks. Yes to Ochre!
Re: Latest Project
Post  trotsky on Sat Jan 31, 2015 3:28 pm
Cheers Fellas, Paintwork back from Peter Gavy today... Beautiful job Very Happy
Re: Latest Project
Post  Weeks on Sun Feb 01, 2015 10:01 am
Seen this Vega earlier today and it looks better in real life ............ Top job by Peter G
Should keep you busy for a while mate Very Happy
Weeks
Re: Latest Project
Post  Thackers on Sun Feb 01, 2015 10:28 am
Just seen this thread Embarassed Embarassed Some great work and photos. Like the idea of a 4 plate clutch, I looked into this with a combo of red and green plates and steels to get it in the basket. In the end I opted for just the standard Rolling Eyes
Loving the paintwork and all the stuff on the garage walls Cool Cool
Re: Latest Project
Post  trotsky on Sun Feb 01, 2015 4:34 pm
Weeks wrote:Seen this Vega earlier today and it looks better in real life ............ Top job by Peter G
................................................About 10 minutes Shocked Wink
Re: Latest Project
Post  Snails on Mon Feb 02, 2015 3:01 am
Bit off topic I know but I always get so jealous when I see pictures of people garages and they are all neat and tidy and have proper shelving for tools and space to move around and work benches to put scooters on and decent lighting and there's a heater, and then I think about my garage and what its like and the shame of the mess its in!
Ho hum... I guess it better than working out on the street under a street light like I used when I was 16!
Shocked Shocked Shocked Shocked Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Re: Latest Project
Post  NIGE on Mon Feb 02, 2015 5:14 am
VERY NICE.GOOD MODS YOU HAVE DONE TO :Very Happy :
Re: Latest Project
