Air Filters
Page 2 of 2 Previous  1, 2
Re: Air Filters
Post  wack 63 on Fri Mar 06, 2015 2:04 pm
Years ago I used a chrome pancake filter on a standard carb,like the car ones .It was similar to this http://www.ebay.co.uk/itm/Pancake-Air-Filter-for-Amal-900-82-6432-/130743354220?pt=UK_Motorcycle_Parts_13&hash=item1e70e9436c
Re: Air Filters
Post  Scooter Paul on Fri Mar 06, 2015 2:12 pm
My ex racer from 1971 had exactly this type of filter. It needed an adapter but worked well.
Re: Air Filters
Post  Snails on Mon Mar 09, 2015 9:16 am
Thanks I'll see if I can find one that has a small enough mounting hole to fit my Sh1/20
Re: Air Filters
Post  Snails on Mon Mar 09, 2015 9:50 am
Scooter Paul wrote:My ex racer from 1971 had exactly this type of filter. It needed an adapter but worked well.
What did it have as an adapter Paul?
This is the smallest I can find which is probably the same as some of the others on the K&N site but might be worth a punt at the price
http://www.ebay.co.uk/itm/Pit-Dirt-Bike-32mm-35mm-36mm-K-N-PanCake-Air-Filter-Blue-Motorbike-Honda-Scooter-/161630718842?pt=LH_DefaultDomain_3&hash=item25a1f10b7a
Re: Air Filters
Post  daz.h on Mon Mar 09, 2015 4:59 pm
Snails wrote:Thanks Daz, Cant seem to find one with that part number - or at least a way of identifying which it is and the K&N site does not allow a search by part number. Also they dont see to start any with an F - anymore at least
http://www.knfilters.com/vent.htm
the 0 in the part number is a zero not the letter o, that might have been the problem
Re: Air Filters
Post  Snails on Sun Apr 19, 2015 11:55 am
I purchased the K&N filter and it works fine but its so loose I think the first big bump I go over it will do one like my last filter. If you try and tighten it too much the tightening action just pushes it off the carb. I'm beginning to think I should bite the bullet and purchase a repo original filter. Do these tend to fit more securely? I don't want that flying off as well
Re: Air Filters
