25 cylinder cowling
25 cylinder cowling
Post  Harlequim on Sun Feb 08, 2015 11:08 am
I'm using the 125 barrel set on one of the Vegas- I know the 75 cowling won't fit (tried it) so I'm guessing I need a J125 cowling yes? How easy do they fix to the engine casing or do they need any adjustment/ redrilling?
Plus- has anyone got one?
Harlequim
Re: 25 cylinder cowling
Post  Scooter Paul on Sun Feb 08, 2015 2:12 pm
No adjustment to fitting. The first time you go over a bump it'll fit even better!
Post  Thackers on Sun Feb 08, 2015 2:28 pm
Scooter Paul wrote:No adjustment to fitting. The first time you go over a bump it'll fit even better!
Yes, you might want to put a crease in the cowl where it would contact the frame just to give a little more clearance
Post  Scooter Paul on Sun Feb 08, 2015 2:39 pm
That's what I meant. It'll do it for you.
Post  Thackers on Sun Feb 08, 2015 2:45 pm
I was thinking of pre paint. Very Happy
Post  Harlequim on Sun Feb 08, 2015 3:24 pm
hahaha, I thought it menat summat like that. Got a 75 cowling in for paint now, but still need a 125. Will only a J125 fit the cylinder or any others?
Harlequim
Post  Thackers on Sun Feb 08, 2015 4:19 pm
Have you looked at Scooter Restorations? They have a J range Sunny head cowl @ £15
Post  daz.h on Mon Feb 09, 2015 9:57 am
I got a j125 cowl years back from scooter restorations, the hole for the plug was miles out, I managed to clean up a starstream one I had and it fitted perfect.
my advice is try it before you paint it.
as for the cylinder cowl groove, I took off my back shocker and marked the cowl where it would touch the frame, then put a socket along the line and gave it a good whack, it left a nice smooth indentation.
