vega to j range speedo cable.
Post  boozee on Sun Feb 22, 2015 2:49 pm
hi, does anyone know if the standard vega speedo cable will work when using j/sunny front hub. cheers.
Re: vega to j range speedo cable.
Post  Snails on Mon Feb 23, 2015 4:06 am
The depends on whether you are planning on using the Vega speedo drive on your hub? I guess that the J range had a different speedo drive method?
Post  gc on Mon Feb 23, 2015 4:55 am
If yours is tbe thin drive I would think not. If it is the thicker type then yes with a bit of tbought.
speedo
Post  boozee on Mon Feb 23, 2015 11:03 am
using the j range speedo drive. ill have to compare them and see if vega cable can be modified. nothings ever simple is it.thats why we love them. Very Happy
Post  trotsky on Mon Feb 23, 2015 12:03 pm
Hi Boozee, I'm happy to be corrected, but even if a Vega one would fit the drive, wouldn't it be too short as they are fitted like a reverse pull cable? I may be wrong but I'm pretty sure you'll need to use a J range cable Question
