electronic kit
Page 2 of 2 Previous  1, 2
Re: electronic kit
Post  trotsky on Fri Mar 13, 2015 11:54 am
Superb, yes that sounds about right. Mine is set at about 24 on tick over & retards to about 16 around 7k......Steve
Re: electronic kit
Post  shand on Fri Mar 13, 2015 1:35 pm
Take it out tomorrow see if its made an improvement, scooter centre sent a postage label for me to send it back so they could prove it didn't fit, I told them I'd persevere with it and let them know how I got on. If there is a possibility these need machining before fitting they should make people aware of this on their website
Thanks for your help in resolving this problem Very Happy
Re: electronic kit
Post  wack 63 on Fri Mar 13, 2015 3:44 pm
Try contacting the maker,Tino Saachi at Lambretta.it He's usually helpful.
Re: electronic kit
Post  trotsky on Fri Mar 13, 2015 4:33 pm
Glad you got it sorted, sadly like many Lambretta aftermarket things, some fettling is usually needed. Not a critism, I'm glad people can be bothered to try & improve things - just an observation. Hopefully this post will help others if they come across the same problem....Steve
Re: electronic kit
Post  li mick on Sat Mar 14, 2015 4:18 am
trotsky wrote:Glad you got it sorted, sadly like many Lambretta aftermarket things, some fettling is usually needed. Not a critism, I'm glad people can be bothered to try & improve things - just an observation. Hopefully this post will help others if they come across the same problem....Steve
this will help me when i eventually do it,can anyone give pictures to refer to? thanks...mick.
Re: electronic kit
