front brake conversion J125/4
Post  madmaex08 on Fri May 15, 2015 4:44 am
Prepping the Lui for this years Eurolambretta I finally found the time to put a use to the Starstream front brake lying around the last couple years. Was a pretty much easy swap, only the space between forklinks is less then with the Starstream - so I could not use the inner nut on the right side of the hub, exchanged it with a small spacer instead. Used a thicker 6mm teflon lined bowden cable and went the reverse pulling way.
The brake works a treat, speedo as well. The only thing I'm Not happy about is the color and routing of the speedo cable.
madmaex08
Re: front brake conversion J125/4
Post  storkfoot on Fri May 15, 2015 5:07 am
I have to ask. Are you riding all the way Question Shocked
storkfoot
Post  madmaex08 on Fri May 15, 2015 5:54 am
you mean all 65km? Sure, why not! Actually it will be 2 Vegas and 1 Lui with a Vega engine that go together on that epic trip. Laughing I´m sure it will be as much entertaining as last years 800km roundtrip to switzerland via the Alps and trough torrential rain Cool
still fighting with my mobile, somehow I can´t seem to manage uploading pictures Question
madmaex08
Post  Scooter Paul on Fri May 15, 2015 6:23 am
He got you there Paul!
Post  storkfoot on Fri May 15, 2015 7:10 am
Indeed. Salzburg Exclamation lol!
storkfoot
Post  madmaex08 on Tue May 19, 2015 5:50 am
Sorry for the odd size pics, but that was all I could manage from the Mobile
madmaex08
Post  Snails on Wed May 20, 2015 9:44 am
Loving the cable tie! Smile
