Brake light switch
Brake light switch
Post  shand on Sun Aug 30, 2015 9:01 am
Does anyone stock these, I've repaired mine several times but now it is just crumbling away, or is there an alternative available
Switch
Post  Admin on Sun Aug 30, 2015 9:32 am
Shand - have you tried Armandos or Allstyles?
Re: Brake light switch
Post  shand on Sun Aug 30, 2015 10:54 am
I've looked all over, rimini and the German shops, nobody seems to have one. I'll look for one to adapt
Post  Scooter Paul on Sun Aug 30, 2015 10:59 am
Series three ones are the same. The only real difference is the riveted on braket. If you have the old one you can make a series 3 fit . The connectors are slightly different but not rocket science to modify.
Post  shand on Wed Sep 02, 2015 1:47 pm
Looked at that, looked like too much faffing about, so another repair, a bit of brass and solder and a fair bit of araldite and its back up and running. Thanks for your replies
Post  Snails on Thu Sep 17, 2015 3:27 pm
You could always fit a vespa cable one to the front brake if you fancy modifying your electrics....
