Jockeys chain guide
Jockeys chain guide
Post  Thackers on Fri Feb 05, 2016 10:58 am
I've just bought a new chainguard from Jockeys Boxenstop, the modern equivalent type. I'm wondering if any of you guys on here could tell me if you keep the standard bottom section on with the uprated part or leave it off completely ?
Re: Jockeys chain guide
Post  Scooter Paul on Fri Feb 05, 2016 11:08 am
I've never used one of these but on the bigger engines I've often left the bottom guide off.
Post  trotsky on Fri Feb 05, 2016 2:24 pm
Hi Thackers, as Paul says, usually leave out, as tension taken up on upside down pullers. On mine i did use both plates supplied, but could of just used top one with no issues i think (see Page 1 of my re-build in projects). Hope this helps.....Steve
Post  Thackers on Sat Feb 06, 2016 4:26 am
Thanks guy's. I should have checked your build thread first Steve, it really is the "go to" topic for all sorts of useful information. It would make a really good booklet on rebuilding one of these machines.
